scrambled image on screen
Unit powers up fine but image is scrambled. I tried patching 2nd monitor & it does the same. Any ideas?
좋은 질문입니까?
좋은 질문입니까?
Same scrambled video on external monitor = bad news. Probably a faulty graphic processor unit and that means a logic board replacement. Try all usual troubleshooting procedures (pram reset, PMU reset, etc). If nothing restore the video then replace the logic board.
Here's a link to troubleshooting steps:
이 답변이 도움이 되었나요?
I'm not looking forward to opening up the monitor but your common-sense response is very helpful. Thank you!
- Mark
이 답변이 도움이 되었나요?
I have a scrambled video problem on mine too, but it only happens when the tilt of the screen isn't exactly right. Couldn't this be a short-circuiting cable?
이 답변이 도움이 되었나요?
Yes it could be a bad LVDS (video) cable or a faulty LCD screen. First connect your computer to an external monitor and if the video is normal on the external then try to reseat LVDS cable both ends. If it doesn't solve the problem, replace the LVDS cable. If you still have the issue then the LCD panel need to be replaced.
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 2,525
