주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
질문 마감됨
Damage after being thrown against ground very forcibly
Help! My son's Ipod is not functioning after it was thrown against the ground. We do not have a tech were we live to get it fixed. It will not turn on at all. Where do I start to diagnose the problem. Thank you in advance for your help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Does it still get recognized? Any visual external damage? Have you tried a reset yet? How did you try to turn it on? what else have you tried?
And another good place to start is to go through the 585 solutions to the right of your question. Good luck.
it does not recognize . the screen is coming off to where i can see the external components and a couple things inside are not connected to the iPod. By the way Bruno, it was not my son who smash it, (he loves it too much) it was my husband (ex-military) who has extremely upset at him.
댓글 달기
답변 2개
선택된 답변
Alma, I think the first thing I would do is to not connect it. If the parts are not properly aligned and you see the inside of it, it may lead to more damage. I suggest something like this this guide or the teardown found on here. Evaluate the damage as you disassemble the iPod. Remember to take your time, not to get frustrated and really study the guides. All parts are available and it's not the end of the iPod yet. Hope this helps, good luck.
iPod Touch 4th Generation 이미지
안내서
iPod Touch 4th Generation Teardown
난이도:
운영
iPod Touch 4th Generation Rear-Facing Camera 이미지
안내서
iPod Touch 4th Generation Rear-Facing Camera Replacement
난이도:
어려움
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I don't think there's a fix for puberty yet. As for the iPod: make sure the battery is charged, so hook it up to the charger for a couple of hours. If the iPod by then still doesn't show a sign of life, then you could try a reset by holding power and home button for about 10 seconds. If a reset doesn't work a service center might be able to repair it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 516
