주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Can not get fuel
I have a 1995-2005 Chevrolet Cavalier 2000. Can you plug the wiring in the wrong place? l had it all unplugged and replaced the head. Now will not start.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
It is possible that the wiring got displaced, but there are so many more things that could have happened after such an extensive repair. Have you checked to make sure that you have spark? Is the timing set properly? Did you check to make sure that you have power to the fuel pump? Does the duel pump come on at all?
No it will not come on
댓글 달기
답변 2개
선택된 해법
mcberta1, this car has an electric fuel pump, protected by a fuse, and switched by a relay. Remember that there is also the switch that will prevent the fuel pump from running unless your engine has oil pressure. The should be a fuel pump test lead, Check on the rear of the drivers side front shock absorber tower. It is usually red and about 6" long with a spade adapter. If you run a jumper wire on that, it should start your fuel pump. If that runs the pump, then you have problems in the oil pressure wiring. Check the fuse controlling this circuit. It should be under the hood behind the passenger front shock tower. There should be an orange wire with a black plastic housing, that is the fuse. Check it for continuity.Of course, a bad crank shaft position sensor can be causing this as well. These are the hardest fixes, since trouble shooting is difficult. Make sure that all wires are connected, as well as all vacuum lines. Hope this helps to get you started.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
If the air bags have been deployed will the car still start
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
There is fuel at fuel rail but seems like just trolled out of pressure valve car had get damage from mi or impact
댓글 달기
답변을 추가하세요
mcberta1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 32
전체 시간: 7,408
