주요 콘텐츠로 건너뛰기
Processor: Intel® Core™ 2 Duo Processor T5750 2.0 GHz
What does it mean when my battery light blinks red
when i click the power button on my Gateway SA1 Laptop, the battery light on the front of the computer blinks red four times.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
The 4 blinks are telling you that there is a fault. The same as Computer POST beeps. Remove the battery and the power adapter and hold the power button down for at least 30 sec. then reconnect the battery and the power. See what you get, should that not work try removing the Memory, and replacing it to a different position. Press and hold the power button for more than 4 seconds, to ensure your computer isn't in standby mode. Should this not work, try to remove the CPU and re-seat it as it may be slightly out of position, or out of it's socket. The other things to check is a bad DC plug, a bad charger (check with multimeter) and of course a bad battery. If nothing works and you need to replace anything, start with the battery. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
my dell laptop charging light is blinking in red and white!!!!!! What does it mean ??????
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
same situation here.
댓글 달기
no for i was talking about a battery, not this type of battery :(
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
justin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 40,974
