주요 콘텐츠로 건너뛰기
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 질문 전체 보기
Touch screen not operating correctly
My sons' DS lite (a year old) was dropped and although no obvious damage, the touch screen is not working properly. Although the touch screen responds to most taps with the stylus, it appears that the positioning is not right and 'off position'.
I have tried caibrating, and although I can tap the stylus on the small red boxes during this process, the calibrating procedure does not 'finish' and check positioning via red squares that turn blue in the final check. Instead, the program keeps looping around the calibration sequence, asking for stylus input for LH top red square, bottom RH and and middle - taking all of this in and going round again and again in this sequence. Is this a programe/software fault or something broken within the screen??? What should I do??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Helen Lowe, it seems to loop because it can not read any input. Sounds like a fractured digitizer circuit. Here is the guide to repair it. The digitizer is available at places like this. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Hi Helen.
I actually had this same-ish problem with my DS a few months back. If you have had it for less than a year, you can return it along with your proof of purchase to either the store you bought it from, or you can deal directly with Nintendo.
If not this sounds like a problem with the touch screen itself. What you can do if you are adventurous enough is take the DS apart and check if the touch cable is loose. If that doesn't fix it, you could order a new one. They are very cheap, around 5 bucks for a new touch screen.
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Helen Lowe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 78
전체 시간: 11,014
