주요 콘텐츠로 건너뛰기
The Asus K53E-MT1 is a 15.6-inch Windows 7 laptop with aluminum surfaces and IceCool technology.
8 질문 전체 보기
Can I resolder the contacts on my ac adaptor input jack?
I have a faulty input jack for my ac adaptor.(It is the jack on the laptop). It is loose, and I suspect it may have broken solder joints. I would like to test that theory, before replacing the jack itself. Does this sound feasible? I plan on using the dis-assembly guide, available on your website.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
Thank you for your input! I Knew that once I found the guide for diassembling The ASUS k53e, it would be much less trouble to fix this thing. I've been fixing just about anything that friends/relatives bring me for many years. I've aquired many interests, and hobbies over the years, & I have a very well equiped shop at home. I am very glad that I found this site while researching this project... I can't wait to begin contributing to the "pool" of knowledge. Thanks again.
Thank you for accepting my answer, and welcome to ifixit. It is always good to have new people with a variety of knowledge that are willing to share their knowledge. :-)
댓글 달기
답변 2개
선택된 답변
Tim Cruzen, it is absolutely feasible, and very possible that this is what causes your issues. . Even if you would have to replace the jack completely, after all it really is only around $5 max and readily available at many places. The soldering is also straight forward.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Its nearly always the positive post that breaks on these. You can kinda rig it to start charging again if you aren't confident in removing/replacing it on the board but for a permanent fix, it would need replaced
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tim Cruzen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 2,500
