주요 콘텐츠로 건너뛰기
iPod Original, Mini, Shuffle, Nano 및 Touch를 포함한 대부분의 iPod 전체 분해 및 설치 안내서.
6220 질문 전체 보기
Why does my iPod 5th generation have lines on the display?
I have tried a hard reset and didn't fix the problem. Also connected it to my computer and resyned it and worked for about an hour and then the lines came back. Do I need a new display?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
The iPod you are interested in, is the 5th generation (Video) or any other one?
댓글 달기
답변 1개
선택된 답변
Danette, it most certainly sounds like you need to replace the display. Of course, you do want to disassemble your iPod, whichever version it is, clean the connector, check for broken pins, corrosion and debris. If all that checks out okay, replace your display. we could give you a more specific answer, if you give us a more specific iPod model. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Danette 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 124
