주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
2001 cavalier wire problems?
my cavalier has been a lil screwy since i replaced the radiator, my speedometer, gas gauge, and car temp gauge always read zero while i drive, also all the egine lights pop up while im driving as well, also my license plate keeps going out randomly is this a fuse problem? or something else?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Jordan Lewis, it's to complex to be fuse issue. Double check all the wiring under the hood to make sure you did not accidentally loosen or disconnect and of the harness connectors. Your errors sound like a bad instrument panel. As for your engine light, I would start by taking to a place where you can get the OBD scanned. Autozone does it for free, and it will give you a better starting point. Here is a decent write up on how fix the instrument cluster. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jordan Lewis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 3,478
