주요 콘텐츠로 건너뛰기
모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
212 질문 전체 보기
Change of hard drive at Apple Service center
It seems that it is almost impossible to replace the hard drive in the new iMac but if the hard drive should break I doubt that I would get a completely new computer from Apple or? Therefore it must be possible to also change the drive at a service center or?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
The swap is not a question of possibility. You certainly can replace a lot of components inside the machine once the display assembly is out of the way. The only problem is that the display is held in by double-sided foam tape, which much be replaced. In the past, Apple has used hard drives with proprietary firmware. Chances are high that this is still the case, though we haven't looked into it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes, it is. It's possible to change drive at Service Center.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mikael 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,227
