주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
208 질문 전체 보기
Can I add hard disk drive in Mac mini with fusion drive?
Hi,
I have 2 linked questions.
Is there still the space to add a hard disk drive in Mac mini with fusion drive or is this area filled by fusion drive?
If it's possible did the additional hard disk drive will be considered as part of one disk or will it appear as another hard disk drive with no benefit of fusion drive?
Thanks for your answers :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
It would appear as a second HD and AFAIK not have any benefit of the fusion drive. See this article
If this answer was helpful please remember to mark it accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks but there is a point I still don't know. Where in physically the SSD drive in mac mini fusion drive? I'm afraid it use the area for second hard disk drive?
You're correct reports are the fusion drive uses one of the drive bays.
A Fusion Drive is two physical drives (1 HD & 1 SSD) which via software made as one contiguous volume. You need to use two SATA Ports and drive storage spaces to create a Fusion Drive.
댓글 달기
가장 유용한 답변
After digging through the manuals for this machine, it appears that the Fusion drive configuration uses both drive bays. The SSD goes in the lower bay and the standard hard drive goes in the upper bay (these bays appear reversed when you're in the machine).
If you ordered the machine without a fusion drive, you still have an empty bay.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
glenic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 1,633
