주요 콘텐츠로 건너뛰기
iMac은 Apple의 올인원 데스크탑 컴퓨터 라인입니다.
8382 질문 전체 보기
Removing suction cup marks from glass after replacement
After replacing the glass front on my imac and removing the heavy duty suction cups, I noticed a ring mark was left behind by each suction cup. Window cleaner did not remove the marks--is there a recommended way to safely remove these marks?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Did you try with with ether or and hydro-alcoholic solution ? only a few otherwise you could make some damage on your screen....
If this answer was helpful please remember to mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Isopropyl alcohol did the trick--thanks for the suggestion!
You're welcome. Thanks for accepting my answer...
댓글 달기
Here is another option, this will work when nothing else will ! http://www.ibreakityoufixit.com/shop/cle...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
try the Ritec Ritepolish a mildly abrasive cream cleaner used for the romoval marks left by suction lifters on glass, mineral and other deposits.
http://www.wholesaleglasscompany.co.uk/a...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
zoomngeorge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 13
전체 시간: 14,226
