주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
need help welding it back?
here is how th happen: my macbook was getting very hot and hoter everytime use it. but i deside to clean it .. i knew it was the fan that was dirty so i got all the tools i needed. everything was going good,, bu i deside to remove the fan.. then things got bad....
i try to remove the conector from th motherboard. but i didnt know how so i pull the black cables and i screw mylself when i saw that i took the entire conction from the motherboard the space on this empty..... so
i was wondering if i can jus weld it back to the motherboard or there is something else you guys recomend me to do
MacBook Core 2 Duo Fan Replacement
on the step 14 and 15 you may know what im talking about... where it says remove this cable ... the attachment ....i rremove that piece please help me help me
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Soldering logic boards is not a DIY level repair... it takes special tools, solder, and lots and lots of practice. Contact a local electronics repair shop... maybe they'll take that job on... otherwise there are services on the web that can do it.
If this answer was helpful please remember to mark it accepted.''
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
use a Mig welder with .450 wire should spot it on.. I not use a 6011 Welding Rod 1/8" would be good.. Then go buy a new computer.. If you screwed up that bad, I would hate to see what happens when you try to Solder the copper strips back to the board..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
olofy777 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 313
