주요 콘텐츠로 건너뛰기
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Is there a way to tighten-up/more resistance the analog sticks?
I am trying to find a way to tighten-up or give more resistance to the analog sticks of the controller. In two areas, first in the amount of pressure that it takes when pushing it down .... i would like to make it stiffer/harder. Second, in the left to right movement in the analog stick, in order to reduce the sensitivity during game-play.
As it stands right now i just barely tap the stick, left or right and it travels way past the intended target, forcing another tap the other way to correct it ........... ant ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
maxx, I just took a look at the analog controller and I do not see anything that would allow any adjustment. I would suggest to replace the stick with a set of new ones. They are relatively inexpensive and it only requires basic soldering skills to replace them. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
maxx 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 39
전체 시간: 9,178
