주요 콘텐츠로 건너뛰기
컴퓨터 수리 질문에 대한 해답을 찾으십시오.
21260 질문 전체 보기
Screw broke inside hole to keep DVI cord in place
I am using a DVI cord to connect my monitor to my graphics card. I noticed that the screw that is used to hold the cord in place has broken inside the female end on the graphics card. No part of the screw is sticking out so I cant use pliers to get it out. Has anyone heard of any other ways to get it out?
Click for picture
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Since nothing is sticking out to grab, I would use the largest screw extractor from this set to get into the hole and unscrew it: Precision Screw Extractor Set
Precision Screw Extractor Set 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I'd didn't see the picture the first time I looked at the question. The whole insert looks like it can be screwed out and then replaced.
댓글 달기
There is so many different procedures....
Take a look at these links :
Remove a stripped screw
The 12 best ways to remove stripped screws
If this answer was helpful please remember to mark it accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
How deep is the screw inside? What you could try is use a needle-nose plier to get the screw out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I've definitely read the post but on the picture I do see a little space between the screw and the outer part, if you have a really small thin plier you could be able to grab hold of it, I've done this many times. http://cl.ly/image/2k423V3g0H2Z
댓글 달기
귀하의 답변을 추가하세요
Fletcher 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,063
