주요 콘텐츠로 건너뛰기
현재 단종된 Minolta 카메라 라인 수리 안내서.
103 질문 전체 보기
질문 마감됨
Dimage f100 digital camera battery chamber door catch is broken
The catch of the battery chamber door is broken off and doesn't stay closed. I am currently using duct tape to keep it closed, but it doesn't always hold. Is there some way to repair this? or get a replacement part?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
댓글 달기
답변 2개
Olivia Crandall, I would definitely replace it. The duct tape trick will eventually fail as well. Anyhow, to get to the pin that holds the door, you will have to partially disassemble your camera. The attached explosion drawing should show you how the part interrelate, as for getting new hardware, the only cover I found is on here but it is only the plastic door. you may have to scour ebay. etc.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
where can i get or buy a camer door for f100
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 452
