주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
PowerBook G4 ribbon cable locking clip
I disassembled my PowerBook G4 and put it back together. Now it doesn't power on at all. The only thing I can think of is that when I was assembling it, I broke a leg off of the small locking clip that connect the keyboard/power ribbon cable to the board. I'm thinking it's not applying enough pressure to make contact. Where can I find this small piece? The top red arrow in the photo shows the piece I need.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
I don't think that's repairable. What you can try is to make a good connection and tape the cable to keep it from working loose. If you are careful you should be able to use some of the yellow tape Apple uses in the computer. Here's a URL to a previous problem solved with tape. Ralph
replace yellow tape inside laptop with..?..
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I used a piece of transparency. I cut it into 3 thin strips, taped them together then slid it under the ribbon cable. It's important to know that the connection is at the top of the cable, rather than under. Once it is connected and working, secure the transparency (or other type of thin plastic) to the ribbon cable...good luck!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
+Good use of alternate materials
댓글 달기
답변을 추가하세요
Andrew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,348
