주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
Is the SSD disk the same in MacBook Pro 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
OWC makes a Envoy drive which you can put your stick in an read it via USB. They make a couple of different ones for the different sticks so check before buying. You can then transfer your data and use the old stick for storage. I think this is the one you need: http://eshop.macsales.com/item/OWC/MAU3E...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
After reviewing the applicable teardowns, I see no reason why you couldn't swap drives. That being said, the 15" comes with twice the storage, so I'd recommend just transferring said data to your new Mac.
Cheers!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mikkel Christiansen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 15
전체 시간: 494
