주요 콘텐츠로 건너뛰기
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 질문 전체 보기
Part of the screen does not work
After replacing digitizer the top (assuming home button=bottom) part (about 0.85 inch) for left to right does not respond. What could be the reason? Looks like it is exactly 1/9 of the screen maybe that could be a clue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Were you replacing the digitizer because it cracked, or because of a similar issue on the original digitzier? It could be a damaged connection that caused your initial problem.
Where are you buying the digitizer from? That could make a difference.
댓글 달기
답변 2개
bad digitizer.. This is common, right out of the box.. 20 percent are bad, and on some, I have even had the connectors come out separate from the digitizer (yeah it was broken off).. don't doubt what your first inclination is, and don't make it any harder than it is..
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Tried another digitizer with the same result. still could be the digitzier (down to 4%). or maybe something else. do you know of a source that offers good pretested digitizers?
Ifixit and MobileDefenders offer great parts with excellent QA.
댓글 달기
The left 10% wouldn't work for me first time. Went back and checked the ribbon connectors and managed to get it in another .1mm and also one of the plastic clips needed sliding in a bit after clipping it down. Perfect after that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
boazparran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 732
