주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
MacBook shuts off after chime.
Replaced logic board, and trackpad(still not working/registering at all) and then bought new battery- NOW it turns on, chimes, spinning icon and looks like a loading bar starts and suddenly SHUTS OFF??? HELP.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
Why did you replace the logic board and track pad? Sounds like damage to the HD, try booting from the Install Disk.
Logic board was bad, then trackpad didnt work so I also replaced but never worked so used mouse til this happened, thot must be battery so replaced that and takes a charge well, starts up, HD & fan start, apple spinning icon w/ load bar starts goin then just shuts off??
Also, have bought 2 of these and dont recall getting a Install disk-idk why I think that but gonna look feverishly.
Oh fyi~added mountain lion right before last issue also.....had snow leopard.
Jeesh keep thinkin of stuff-sorry. FYI~reset smc pram already
댓글 달기
답변 1개
선택된 답변
The newer machines don't come with a DVD disk. Boot up holding down the "r" key to run a repair on the hard drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Held down 'r' on boot up-nothin. No F-key or command?
ok-used w/ command-we'll see....*fingers crossed* and thnx 4 tip ;)
okay- recurring issue w/ 250GB TOSHIBA MK2555GSXF Media-is that HD? Says cant repair= backup, and restore. ?
Probably just the ribbon connecting the hard drive to the logic board died and needs replacing.
댓글 달기
귀하의 답변을 추가하세요
taber1969 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,973
