주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Dust underneath the Screen
My iPhone5 has dust or dirt underneath the screen. I hear its a common problem, but it annoys me so much. I can't get the phone replaced but I tried to see if the Apple store could open it up and clean it but they could t do it. What can I do to get rid of it? Anyone have any easy tricks?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
you can replace the LCD assembly, can buy from partsifixit, it is good price with high quality.
댓글 달기
답변 10개
선택된 답변
The screen is fused to the glass. Tue only fix is a new screen assembly, which can be found here: iPhone 5 Display Assembly (LCD, Front Panel/Digitizer Only)
The guide can be found here as well: iPhone 5 LCD and Digitizer Replacement
iPhone 5 LCD and Digitizer 이미지
상품
$39.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
That's what I heard that the glass and the screen are fused together so like how does dust get in there?
My screen was clear a when I bought my iPhone, but the screen got dust a couple of weeks ago, so I don't know what this is happening now...
댓글 달기
가장 유용한 답변
I managed to open it and clean the space between the LCD and the backlight based on the video from the below link.
https://www.youtube.com/watch?v=SWtwIA9G...
However, it was really really difficult to make dust free. After removing white dusts, black dusts came up. After cleaning black dusts, white dusts came back. You will need an alcohol swab, a clean microfiber towllette, camera lens dust blower (Don't use the one from canister as it sometimes blows some liquid that is very very difficult to clean up), and Scotch Magic tape.
Long time ago, I thought it's sealed around the space, but it was clearly detachable. Try or not try, it's up to you.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
This worked for me but dont use type on the backlight it will stick and could damage it use a dust blower
댓글 달기
Are you sure it's dust? I've seen burned pixels that look like dust. Tilt the phone and look at the LCD from a sharp angle, if the speckle disappears it's not dust.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I purchased a replacement screen through iFixit almost a year ago. Yesterday, I opened my phone to remove dust behind my rear-facing camera and straighten my home button. Once I reassembled my phone, I noticed a small hair and dust particles when the image on the display was white. You can't see them with darker backgrounds but still an annoyance. I don't see how a fused display which had no dust behind it gets reassembled and has dust.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Some screens can be refubushed just using front glass over the lcd some don't fuse them but just stick it around the edges hence y you may be getting dust inside..
Had a few phones like thy come it for screen repair were the glass has come Completely off and you just see the lcd
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
pretty sure I just now accidentally pushed dust under my screen :/ I noticed that the little speaker opening had some dust and what im assuming is ear gunk build up and thought, gross, I should clean that. Used a q-tip with little bit of alcohol and a folded paper corner to clear it out... And apparently pushed some of it under screen at same time. Just posting as a warning to anyone else, don't be dumb like me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello ,
i have the same issue , it's mean that the screen is unsealed ,is it safe to open it and clean it , if yes how can we reseal it again ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have the same issue, i figured out that the frame of the screen assemble had an opening at the side which allows little particles into it...this settles at the silvery shiney surpace behind the screen....tried cleaning it but it went off abd left wiped imaging on the main display...need a better solution
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Particles of dust can get between the LCD and the sheets of the backlight and they are a nuisance especially on white backrounds . Two ways to get rid of them: replace the whole screen (easy but expensive) or buy a new backlight, peel of the old one carefully, and replace it (difficult but cheap). You will need minor soldering skills to desolder the old backlight and solder the new one. Also you need to take care not to trap new dust particles under the backlight in the process.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My camera has dirt in it and I don’t know how to fix it ..my camera is all foggy now!:( I’ve tried cleaning it off but it’s in the phone
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Eric 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 13
30일 전: 37
전체 시간: 42,438
