주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
질문 마감됨
After Screen replacement, bright spots in the corners
Hey Guys.
I'm repairing iPhones since 3 years now, but the last two iPhones showed some bright spots in the corners. They come, when I push the edges of the glass (not very powerful). This can't be normal. Is it possible, that I have any repairing mistake by attaching the Front Assembly on the frame?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
no its not your fault, you have a cheap copy screen. buy a better one and replace
해당 답변은 도움이 되었습니까?
점수 2
댓글 9개:
Im having the same problem, i dont know why this is happening!help!
What iwillfix said: you probably have a cheap low quality screen.
Does this problem has to be with the lcd or with the mid frame?
It is the backlight "bleeding" from the LCD.
It happens when i press the screen a little bit hard! Does anybody knows why this happen?
댓글 4개 더보기
댓글 달기
If the bright spot appears when you press the screen, then the frame below is pressing against the LCD. LCD displays do exhibit some discoloration when forcefully pressed. But if the discoloration appears even with normal force. It is highly possible that some parts are not installed properly or the display is too thick. Causing parts pressing against each other
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is the screen that is a bad quality screen because i bought an original one and it didnt show those marks when pressing it harder!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 5,129
