주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
20 질문 전체 보기
질문 마감됨
black plastic between de screen and the keyboard?
I want to change that black plastic peace in the outside of my mac between the LCD and the keyboard, Where can i find it???
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Thanks!! I was talking about the hinge clutch cover! Is that piece for an macbook late 2008?
댓글 달기
답변 2개
선택된 해법
It's not sold as a separate piece. It comes with a top case replacement. I haven't found what material it's made of, but if you did you could use the old one as a template. It's got to be some kind of heat resistant plastic.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
See step #26 of this guide for removing the clutch cover: MacBook Unibody Model A1278 LVDS Display Cable Replacement
댓글 달기
Hi,
Are you referring to the front lcd glass/ bezel cover: http://www.ebay.com.sg/itm/New-Apple-MAC...
This one listed on ebay cost around $28USD (brand new). Replacing it aint easy as it is held on by glue which you'll need a heat gun to soften the glue. Plus a lot of strength! >.<
If it is the hinge clutch cover: http://www.ebay.com.sg/itm/Macbook-Unibo...
This one is listed on ebay for about $16USD.
Replacing this is very easy.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hi i found this on ebay: http://item.mobileweb.ebay.com.sg/viewit...
Im not sure whats your exact model but this one above is for model A1260. Do verify before buying. Hope it helps! :)
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,048
