주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
E38 generation of BMW's full size luxury sedan.
no heat inside the car
Car not putting out heat
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Oluseun, that can be caused by multiple errors. Check to make sure that you have enough antifreeze, check the hoses to your heater core, the top one should get hot/warm. Stuck thermostat could also keep it from getting heat. You also want to make sure that your heater fan works, and that the flap servos are working.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
What model/engine ?
Typically it's the heater valves as well as the electric pump for the heater matrix;
This might help, it's for M67 engine but the part is largely the same for other engines too (as well as other models like E32 and E31)
E38 Heater Valve Replacement
이 답변이 도움이 되었나요?
점수 1
댓글 달기
have new thermostat just the power supply to the small pump 6v but pump states 12v no power from black plug only white plug 6v is there a re lay for this unit
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Oluseun 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 9
지난 30일: 29
전체 시간: 3,018
