주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2133 질문 전체 보기
1 GB of RAM and only 2 slot
I have only two slot and each one have 0,5 GB of RAM. I want to increase the RAM what I should do? Are there only dome kind of RAM compatible with the PC or I only have to use two RAM of the same type?
thanks you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Giovanni Riva here are the memory specs for your motherboard :2 * 184-pin DDR2 DIMM slots – Dual Channel DDR2 533/400 non-ECC , un-buffered memory (Max 2GB)
If in the shop I say as you said, the shop assistant will understand. Right? Becouse I don't understand any word between "motherboard" and "max "GB". :D However Thanks you again!
I am sorry about that. I should have asked if you understood what I said. Yes, any good repair shop should know which memory you need. Your motherboard only supports 2 GB memory. You will need 2x1GB memory modules.You would need something like this http://www.archmemory.com/ram.cfm/Packar... Hope this helps, good luck
Google translation:
Mi dispiace per questo. Avrei dovuto chiedere se hai capito quello che ho detto. Sì, qualsiasi negozio buono stato di manutenzione deve sapere quale memoria avete bisogno. La scheda madre supporta solo 2 GB di memoria. Avrete bisogno di moduli di memoria 2x1GB. Si avrebbe bisogno di qualcosa come questo http://www.archmemory.com/ram.cfm/Packar... Spero che questo aiuti, buona fortuna.
Thanks you! I didn't understand the technical specifications. :( But the important thing is that the dealer know what it means. :) (And yes, google translation work good enough, only the tenses are a little bit confused) Thanks you again, as always your help is so much useful!!!
댓글 달기
답변 3개
선택된 답변
Giovanni Riva, all this will depend on your motherboard. Some will take different memory size, others will not. I would replace both of the modules with the largest memory that your motherboard will accept.
해당 답변은 도움이 되었습니까?
점수 3
댓글 11개:
How I find out what is the largest memory size that my motherboard accept?
Who made your motherboard? Any numbers on it?
So do I must open the PC and see if there are some words that ID the motherboard?
There are plenty of programs out that will identify your motherboard and system, as long as it still functions. I use SiSoftware Sandra
images added.
댓글 6개 더보기
댓글 달기
Go to crucial.com and download the system scanner. Then the program will scan what kind of computer you have and show you the list of parts for your computer such as RAM, Hard drive and Solid State Drive
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
http://www.findlaptopdriver.com/spec-msi...
it says here that it can take max 2gb of ram, so my guess is that u can stick 2 sticks of 1gb ram in it max. The link specify's the type of ram supported.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Giovanni 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,349
