주요 콘텐츠로 건너뛰기
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8 질문 전체 보기
Screen not activating start button flashing
Monitor would not 'tun on'.Start button on bottom right hand corner was flashing and screen was blank.
Unplugged all leads and power to PC to get this going.
Don't know why this occurred.
Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Warren, the flashing LED can be an indication that your monitor is having power issues. Recheck your connections, if all of them are okay, disassemble your monitor and check the caps on the power board. Use these guides to work on your monitor. It does sound like you are having a few failed capacitors. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try using a different VGA cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks ,not the answer I was hoping for.but sounds correct.We managed to get it going all night then this morn same.but can't clear it this time.had a long hot summer so maybe board dried out etc.Thanks again
댓글 달기
i think symptom due to monitor.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a windows 11 monitor but the light by the intel core i7 is blinking and my screen is just black and idk what to do.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Warren 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 22
전체 시간: 23,108
