주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
질문 마감됨
Can I install 2x2,5 with a hdd-cage instead of the 3,5"?
I want to know if i can install 2 x 2,5" instead of the 3,5" HDD with a 3,5" hdd-cage?
Could there be a problem with length of the sata and power cabel?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I had 2 x 2.5 inch sata drives installed in the 3.5 bay.........
I had mine in an adapter cage, as you mentioned. The 2 drives sat in this plastic cage and then the plastic cage just slid into the 3.5 inch bay, really simple....
There will be some fiddling with cables as the sata power and data ports for both drives will be close together, but its not a problem, both drives will be at a similar distance to the PSU...
Have you got a modular PSU........this would make it easier with the cables....
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i have an original imac, with no modifications....
so i think i didn't have a modular psu if it's not build in from factory.
i will take the ifixit.com cable-set or can i use other cables?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 268
