My iPhone says "charging is not supported with this accessory." Why?
I tried to connect my iPhone to my computer. Tried charging it through my wall outlet, my radio, the cable, and every iPhone charger i have. Plus I had my iPhone put to unlock, so i don't want to lock it again. Help me :( What do I do???
좋은 질문 입니까?
댓글 6개
The first thing you want to make sure off, is that you have a proper cable. I've had an aftermarket cable that gave me the same error. If your cable is a proper one, replace the dock connector.
oldturkey03 의
Priscilla Martinez, that usually has to do with a signal from the dock connector. If you have a cable or a device that is not properly identify through your dock connector, it will give you that particular error message. Of course if you have a good cable, it is the dock connector that is at fault. The other way to test it, is by using a docking station that worked before, and see if it still works.
oldturkey03 의
try cleaning inside the dock port..you often get this message if there is debris on the pins.
pollytintop 의
yep my had a big ol' piece on the pins - thanks - alcohol to the rescue
Sandra Griffith 의
I have an iPhone 4 and when I use my charging cords or the speakers made specially for iphones a lot of times it will say it may not be supported but it will work to play music but I will not charge .....any ideas????
Ashley Kravatz 의
댓글 1개 더보기
