주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
질문 마감됨
White screen (nothing else). Works perfectly with external screen.
Hi Everybody,
My MBP suddenly went white while I was watching a movie. I manually restarted it but it only displays white on the screen and nothing else (no logos, no spinning balls - the sound is working fine though).
I could use it blindfolded (I can log into it, run Terminal.app then type 'say hello' and I can hear 'Hello') so I connected external screen and confirmed that everything is working fine.
Questions 1: What are the chances that it is LVDS cable issue (how can you test without buying one:)?
Questions 2: Is it definitely screen problem?
Questions 3: If it is screen problem, can I replace the screen from my old MBP (Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW)) - will the screen fit?
Thank you very much for all your answers and concerns.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Please give us the last three figures of your serial number
...H2H (thanks for looking into it!)
See if you have another serial number, that one may be for the logic board
Full S/N (from Invoice): C02F9XPVDH2H
Product ID: MC724X/A
댓글 달기
답변 2개
선택된 답변
DIY "shade tree" test procedures are pretty limited. Since the external monitor works fine the problem is most likely in the internal chain... the cable would be the easiest cheapest place to start. I know of no DIY way to test/eliminate the cable other than swapping.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I will try to swap the cable out. I don't mind going and buying a spare screen but kinda afraid that both of them do not solve my issue. I will let you know how I go. Thanks for your answer, machead3
댓글 달기
You could take it to a genius bar if you're still in warranty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Not under warranty anymore:) How much would it cost just to get it examined, do you know by any chance?
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 518
