주요 콘텐츠로 건너뛰기
The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
11 질문 전체 보기
The left side of subwoofer
Hello i have to repair the left side of subwoofer in skullcrushers, and there is a question:
the subwoofer has 4 slots:
"LV+"
"LV-"
"RV+"
"RV-"
which of them should be paired with following cables:
"red-blue"
"red-gold"
"Green"
"blue-gold"
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Perhaps you could take apart the right side and see which ones match there (from my experience in audio, they should be exactly the same)? Bonus Internet points if you make a guide for it :)
댓글 달기
답변 1개
선택된 답변
bartek94to, attached image is what I come up with on the opposite end. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
I did it like you had wrote me. But i can't even hear any bass : | maybe this subwoofer is just broken
Try to bypass and go right for the speakers. See if that makes a difference.
i don't realy know what do you mean : p and i am sure that i couldn't do that, cuz i am novice : | Have you got skype?
Try to bypass the amp. You will need the end that comes from the jack. See the repair 3.5mm jack on the device page Repairing Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm plug Connect Gold, Blue Gold RV- and LV- Red/Green to ground, L+Blue and LV+Green to the left, and R+ Red and Red/Gold RV+ to the right. sorry, can't Skype until I get off work. My Skype ID is in my profile.
댓글 달기
귀하의 답변을 추가하세요
bartek94to 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 1,033
