주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Can I replace the transparent ribbon cable on MacBook keyboard?
Hello,
There is two ribbon cables for the A1181 Macbook keyboard. The silver one and a wide transparent ribbon cable with silver stripes.
I've broken the last one (changing the hard disk).
As i m not native english, i post a pair of photos.
Can this ribbon cable be repaired/replaced?
Thanks ifixit community ;-)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Hi polfdzpub,
I am not sure what exact model you have... But in any case, based on this guide here on iFixit (step 24), the ribbon cable you are needing has 26 pins.
Here you find such a cable, although it is 20cm long. But it might fit in your case. For that price, I would give it a try.
Steffen
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks Steffen, i will get a try and post here if it's a successful solution. I hope so!
Anyway, thanks again!
댓글 달기
Looks like you will just have to replace the upper case to repair.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for answering.
I hoped there was a cheapest solution ...
댓글 달기
The keyboard is riveted in place with melted plastic. There's no way you could just put a keyboard in without totally destroying it ... So it's quite impossible to change this ribbon cable.
Thanks anyway!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did the same mistake:( broke the cable just from exact same place:((
Are you shure it is immpossible to replace this ribbon cable???
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
polfdzpub 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 7
전체 시간: 2,363
