주요 콘텐츠로 건너뛰기
Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
20 질문 전체 보기
No power acknowledged by Laptop? Neither battery nor external power?
Defective Screen(cracked) was replaced. Initially worked but after reaching home shows no signs of leda blinling even after connecting external power suppply which was checked & is perfectly working. Now due to no power shown it obviously is in no condition to start.
Where do I start trouble shooting?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
Sudeep Chatterjee, I'd start by double checking the work you did. Make sure that all the cables are properly connected. Check the DC jack to make sure it is properly seated. Then check the AC adapter for proper voltage. If it does have the proper voltage, plug it in and measure the voltage on the DC jack of your logic board, to see if it does work. It seems like you have a main power problem which occurred after your repair, so start with that first.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Sudeep Chatterjee,
Just to be sure i would make a hardware reset.. I have had similar issue where either charged battery or AC-adapter is accepted and Laptop will not start.
Does Caps Lock flash? and do Power button flash in a pattern?
This did help me to get it started.
Unplug the power cord --> Remove the battery --> Hold the power button for 60
seconds --> Connect the power supply then try to switch ON the laptop and later
put the battery back into the laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sudeep Chatterjee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,526
