주요 콘텐츠로 건너뛰기
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
30 질문 전체 보기
Can the charger unit of the phone be repaired
the metal part of the charger in the phone has come out.I need to know if it can be repaired or does it have to be replaced.is there an ifixit guide for the breakdown of the blackberry curve 8520 and a guide for the replacement or repair of the charger
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
paul murray, Here is a decent video and here are some good instructions to work on your phone. There are some great guides right here for you to follow. It is a repair that requires good soldering skills and a small soldering tip. You will have to de-solder the old connector and re-solder a new one. Check on here for a similar repair. The port is available at multiple places like this. If you need more visual instructions check on here.Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
paul murray 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 404
