Why does my tablet respond to S-Pen but not my fingers?
I just finished repairing one problem I had, where the screen gets all discolored. Once I closed it up and started it, it would not respond to my touch, nothing. I tried the S-Pen and it worked fine. Does anyone know what could have caused this? I reopened it and check the ribbon connections, the only one that looks questionable was the central ribbon cable. Now, I don't know much about electronics, but I noticed that on all the other connectors for the ribbon cables, there was a locking switch. I don't think the connection this ribbon cable has one, and I fear that out of ignorance I may have damaged the connector attempting to flip the non-existent locking mechanism. I believe this to be the cable that connects to the front screen (Not the LCD), and is what is used to communicate the touch input. So I think this is where my problem lies. Can someone enlighten me with their perspective on this issue? I think it must be a damaged connector (requiring me to get a replacement motherboard), the ribbon cable isn't fully connected (tried my best), or something else I am not seeing. Hopefully it is fixable, I would hate to have to scrap a tablet just after 5 months of use. Could it possibly be a broken or damaged digitizer? I have dropped it a few times.
좋은 질문 입니까?
댓글 8개
Hi it is a commen problem and I don't understand that Samsung is not having a better product. It make you think if it was worth the money.
Hans stofberg 의
i have note4 edge its option and back space sensors are not working while using only it works with the pen can anyone tell me how to fix this problem ..../
jawed jmy 의
I have note edge it is not walking by finger only by spen
king maloo Mugsthfaaa 의
Sometimes when the phone does not work using your finger but the S pen is, and you have tried to go to your settings to disable the S pen function then you should visit the nearest service center for assistance, it could probably be a software issue .
Doctor 의
I had the same issue, I had to call my phone carrier, back up and factory reset my phone and no luck so they replaced the phone. It is a software issue.
marquitaraquita 의
댓글 3개 더보기
