주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
How do you fix a disabled I phone 4?
'''I have had an iphone for 2 years now. my friend locked it up and now it says "iphone disabled connect to iToons". i don't know how to do it and my sis has already tried this and couldn't figure this out. i also dont know how to get to DFU mode so i need step by step ways to do this... ever little step... can you please help me?:) "
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 19
댓글 달기
답변 2개
선택된 답변
alex, try to go into DFU Mode and restore. DFU Mode Connect your iPhone to your computer Turn your iPhone Off Press and hold the power button for 3 Seconds While continuing to hold the Power button, press the home button as well for 10 seconds Keep holding down the home button, release the power button for another 10 seconds iTunes should now detect the iPhone in recovery mode, press OK, and restore your iPhone. Now you can release the buttons. If you have not reached this point, then you have not entered DFU Mode. Check this video to see how to do it. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 7
댓글 달기
how to unlock iphine 4s disable
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,317
