주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
597 질문 전체 보기
Broken head phone plug inside
The headphone plug is accidentally broken off and part of it is left inside the phone jack. This problem causes computer speakers not to work.
My question is: Can I just change the headphone part, instead of changing the whole logic board?
I tried several methods found on the web but non of those have worked for me and I don't want to pay the "amazing" price tag that Apple charge. (over $700), and per previous experiences with Apple repair center, Genious bar or whatever you want to call it, they don't change the parts.
Thank you for your info an input.
My MBP:
2.6GHz quad-core Intel Core i7
Turbo Boost up to 3.6GHz
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Yes it is possible to replace the HS connector however it looks to be a surface mounted connector which means it wont be easy. It would require some SMD rework skills and all the necessary tools. Unfortunately I cant find a close up picture in any of the guides (so far) so I cant be any more specific.
THIS is something like what you are after however you need to find the correct pin configuration.
Have you tried removing the piece that is stuck in the connector? The male connector shaft is hollow so you may be able to get something like a small drill bit, knitting needle, scribe or some other metallic thing and push it into the hole in the remnant part and pull it out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
'Have you tried removing the piece that is stuck in the connector?'
I have tried the Qtip and superglue, into the jack. ( used caution). I tried Tweezers.
I purchased few tools to take the logic board out. I tried to take the piece of pin stucked inside but no luck this time. It seems that something is holding in place very tight and it was no way to take it out.
I purchased the an USB Audio adapter 3.5mm (iLuv), cuz even if the HeadPhone Jack is fix, I am not going to use it anymore, isn't safe and it is costly. I guess the USB adapter is secure and i was told that I get a better sound than the original HP Jack.
Thank you for the prompt reply.
댓글 달기
귀하의 답변을 추가하세요
zito1984 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 6
전체 시간: 268
