주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 질문 전체 보기
Games play right, blank white screen. Help?
So I recently dropped my GBA SP on the ground and for some reason the screen is just white whenever I turn it on. I can hear the game working and it seems like everything else works fine, it's just the screen is totally unresponsive. The GBA SP is the AGS model 001 (The one with only a front-light). I really want to fix this and i'd like to do it at home. Can you please find me a link to a how-to video or a step by step walkthrough?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Isaac, here are the guides. It is possible that your LCD broke, or that the connection came loose. Use the guides to open it up and check on the connection first.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi there! If you were able to fix the problem, please let me know what you did. I have a similar problem, only my screen is black, with colorful vertical lines. So, it doesn't seem the LCD isn't working, it would seem maybe the ribbon to the screen is detached etc.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I had the same problem and did what oldturkey03 said and it now works.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mine is working but after startup it turns white and I need to fix it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Isaac 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 24
30일 전: 75
전체 시간: 18,973
