주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
iPhone turning off while doing something.
Hi,
i have an iphone 3gs. The problem is, that- it is turning off even it has 50% charge. Its happening when im doing something on it, like playing a game. I have replaced a battery two times. Nothing has changed. Do you maybe have any ideas what can it be? Maybe I need to replace something else, and it is not the battery fault?
Sorry for my english, it's not my first language.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Daniel, since you already replaced the battery, and I suppose it is the right APN number (remember that there was some issues with the 3GS batteries), then my next step would be the dock connector, inspect it for any broken, bend or corroded pins, replace it if necessary. If that does not resolve the issue, you may have trouble with the PMIC on the logic board. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for your answer. I checked the battery APN and its 616-0435. So it seems to be right. However I took the very oryginal battery from another iphone 3gs. So now its working, I will see what will happen next.
Definitely sounds like a battery issue. I would replace the battery.
댓글 달기
답변을 추가하세요
Daniel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 136
