주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
Flickering backlight... how do I fix it?
I just finished assembling a new front display (LCD and digitizer) on my Verizon iPhone 4 because I had a cracked screen. Everything works great, except the backlight on the screen seems to be flickering...it's very subtle, but soon it will start to drive me crazy Does anyone know why this might be, and how I could go back and fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
try turning off the auto brightness.
if that didn't work you have no other option than replacing it. it a common fault on these copy's
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yep: my aftermarket replica screen had flickering/pulsing brightness. Over one month of use did not magically break it in or burn it in. Auto-Brightness has nothing to do with it, in my instance. I replaced this copy with a used Apple original, and problem is gone. It was just a lousy copy.
댓글 달기
답변을 추가하세요
Katie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 4,089
