주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
Can I add a sim card slot to the iPhone 4 CDMA?
Hi, my friend gave me his old iphone 4, but it's on verizon, and I am on T-Mobile, so I was wondering if I can access the iphone's internals and create a sim card slot. I don't really care about looks, I can hide it in a case, I just want to upgrade from my crappy LG. Any help is appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
You are trying to compare Apples and Oranges. One is a CDMA phone (Verizon) while the other one (AT&T, T-Mobile) is a GSM phone. They do have different hardware. So it is not as easy as cutting a slot in the case, the SIM card reader will have to be connected to something that is not supported by the CDMA version.
Contact T-Mobile they can assist you with a CDMA account now.
댓글 달기
답변 5개
선택된 답변
I don't think your idea would be possible - IIRC the case has significant differences compared to the GSM model so trying to shoe horn a GSM board etc into the case will likely not work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
But couldn't I just add it onto the back with tape and cover it up with say a case?
No. You are talking completely different phones in somewhat similar cases.
is iphone 4 cdma has sim card built in on the back? can i change that built in sim?
댓글 달기
No you couldn't
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
alot of difference between the iphone 4s cdma and iphone 4s gsm inside the board and cdma iphone 4s do not work in other country with out of usa and many other country of europ''
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have iphone 4 cdma phone is problem in sim tray
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same issue, I am on Mint and my iPhone 4 is stuck on Verizon for all eternity. After trying so hard, I deduced I should just buy a GSM iPhone 4 for about $60 on Amazon with a SIM slot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Peter Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 16,406
