주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
Intermittent display screen related to angle?
I replaced HD and RAM on my 2006? Macbook 2 GHz Intel Core 2 Duo Memory:4GB 667 MHz DDR2 SDRAM
It has been working fine for 2 months.
Now, the screen will black out-- sleep? but won't display anymore. If I almost close it and slowly open the screen it comes on until it's almost 90 degrees...further opening causes black screen.
Intermittent means loose connection? or something worse?
What do I do to diagnose this problem-decide if I can afford or should attempt to fix it.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Yes thank you. I see "DIFFICULT". I read what a splunger was...I think I'm WAY out of my skill set here. Any advice on this part?
The guide is good even for a beginner. But it's not an easy fix. Maybe we can get you to a good tech. Where do you live?
댓글 달기
답변 2개
선택된 답변
You probably have this machine:
Apple MacBook "Core 2 Duo" 2.0 13" (White/06) Specs
Identifiers: Late 2006 - MA700LL/A - MacBook2,1 - A1181 - 2121
I would replace the inverter cables, here's how: MacBook Core 2 Duo Inverter Cable Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
live in the southwestern tip of VT in a rural area. This is NOT apple country. The nearest apple store worth driving to is in Albany 60 miles away. There's a place called Small Dog--just opened in Rutland VT recently--but I need an approximate price of repair--given my limited funds and 06 laptop...
I fear there are no techs in these mtns!
ifixit helped me with the Ram upgrade, and then a HD transplant...I just don't have the overview of what else could go wrong...If it was a car, I'd be askin' if it's more like I'm going for a 'classic car' or is it a loosing proposition?
Is there a different fix (something with an easy rating) that is a more contained component swap (as the HD replacement was) ?
Thanks!
any help will be appreciated!
HAPPY SUMMER!
댓글 달기
I live in the southwestern tip of VT in a rural area. This is NOT apple country. The nearest apple store worth driving to is in Albany 60 miles away. There's a place called Small Dog--just opened in Rutland VT recently--but I need an approximate price of repair--given my limited funds and 06 laptop...
Thanks!
HAPPY SUMMER!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
georgiaruocco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 145
