주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dynabook(구 Toshiba)에서 제조한 노트북입니다. Toshiba는 노트북 사업부의 지분 100%를 Sharp에 양도했습니다.
Has a white blank screen
hi, i have toshiba satellite A 505-s6980 laptop
has problem with White blank screen. Every time I turn it on, is has a white blank screen.
I did turn it on and push F 8 several time still not working properly.
need help please>
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 14개
chjohn2122000 have you tried an external monitor ?
Mine works when plugged into another moniter but I'd like to use it without the extra hassle how do I just fix the screen I know it has to be simple
Hi @heavenlee18
What is the exact model number of your laptop?
Uninstall your display link core software in Control Panel Uninstall Program also the USB adapter in device manager reboot and install Display Link Software. The USB adapter will install automatically. Plug your monitor again.
I have the problem too! I have even tried holding the power button but that turns it off. I have also tried holding the f11 key while the white screen was there and all I heard was BEEPBEEPBEEPBEEP its so annoying
댓글 9개 더보기
댓글 달기
답변 8개
선택된 해법
Connect to an external display. If you see the same thing your video card is causing the problem. If the screen appears normal (desktop) you have an internal display chain problem. It could be a cable, or the LCD. More information and some basic investigation is required to offer you more help.
If this Answer is helpful please remember to return and mark it Accepted.
이 답변이 도움이 되었나요?
점수 13
댓글 3개:
At least I now know what the issue is. Thanks!
toshiba satellite 655 boot white screen, connect external monitor and work again
hi i have a toshiba satellite L840 its screen started turning white when i used it for 8 hours straight is there something i can do?
댓글 달기
PROBLEM SOLVED
on my Toshiba Satellite Windows 7
Hi, I had the same problem with a Toshiba Satellite laptop, I found the problem: Trojans.
Heres is what I did:
Start your laptop, and while it is booting press F2
a boot menu options appears, select something with command prompt ( I do not remember exactly the words)
Now a command prompt window will appear, just type: explorer.exe
this will load windows in safe mode.
Now download this little but powerfull program: Rkill from this site: http://www.bleepingcomputer.com/download... (if you have another computer download it there, put it in a usb flash drive then run it in your afected laptop, this is what I did)
What Rkill will do is stop any malicious process, so you can run a antimalware program.
After you run Rkill, download this antimalware program : Malwarebytes from this site: http://download.cnet.com/Malwarebytes-An... run it, select Quick scan, after the scan, select the afected files and select remove. After this it will ask you to restart your computer.
It worked for me!
I hope this will work for you guys, please let me know
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
The screen goes white right after turning on the laptop. At this point no software even loaded. it is in POST test and problem is there. It can not be a software issue .
댓글 달기
Permalink
Thanks very much for your great Input...
I have a Toshiba Satellite L755, and I had a white screen for the past few days and I was very angry since it has 2 years only so I did search on Google and I came to to this site hoping to get an advise and I read your input and I connect an external monitor and I did see the computer is working, and I did another search and I find a site selling computer's LEDs and they have video on how to change the screen and I did check it and I find the video cable is loos ... I used my glue gun to hold the cable and the computer back to work again .. thanks again for your input ...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you have already tried connecting to an external screen, then it leaves you with 2 possibilities.
Either a wiring issue or LCD screen issue.
Check this video on youtube, shows you how to repair it.
https://www.youtube.com/watch?v=u3rlnuAf...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try using an external monitor and see it it properly works or not. If the external monitor works fine the you need to check internal cables going from LCD to motherboard could be near to the hinge make sure that there isnt any lose contact or carbon inside.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
That's already been advised.
Pls, I have a Toshiba laptop satellite c850-f21c. It turned blank after booting n av tried the shift +f8 stuff t dint work pls what should I do
댓글 달기
try to hit the onboard vga beside the cpu with your rework station hitting mechine
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The solution is just simple just remove the battery of the laptop and it should also not be connected to the power. Leave it out for like three to five minutes just for a while then return the battery and switch it on. It just means your computer was hanging I think that's the right word.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's very simple your computer only has hanging files .Go to your history and clear out programs that are open close all out . Then ur computer should be just like new.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
People saying t clear history files and stuff… how is a person to do that if they have a solid white screen and can't do anything??????
as above - can't get into files - how do i remove the white screen to access the history
댓글 달기
답변을 추가하세요
chjohn2122000 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 24
전체 시간: 103,746
