주요 콘텐츠로 건너뛰기
AirPort Extreme 베이스 스테이션과 함께 출시된 이 하드 드라이브 장착형 제품은 Time Capsule NAS에 802.11ac 속도를 제공합니다.
How do you get it apart in the first place?
Just got mine and I can't understand how you got the black base to separate from the white tower. I'm stumped at step one!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Taylor Barcroft, I would check on this teardown. Pay particular attention to the steps outlined on the right hand side. Follow the link in step 2. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Go to:
Apple Time Capsule
And all will be revealed :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Theres a little more of an opening on the underside of the black base cover where the power cable goes into. There's enough of a space for butter knife tip to get it started. I prefer the metal spudger or metal anything, its on there pretty good. Just be careful the power connector is in that spot so be gentle and don't go to deep and break a clip. The other spot to watch for is where the light is going to deep could severe that wire. Other than that all the other spots are safe and you can be a little mean with it, the cover is pretty resilient you might mark it up where you decide to pry but it is on the bottom where no one sees it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Taylor Barcroft 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 6,117
