주요 콘텐츠로 건너뛰기
Repair guides, troubleshooting information, and service help for refrigerators manufactured by General Electric (GE).
234 질문 전체 보기
Temperature Problems (will not cool)
I have a GE Profile refrigerator (model PSS26MSWASS) side by side refrigerator. It does not want to cool down.
I have broken it down and found that the evaporator motor was not starting. If I start in manually with my finger it will run. If I unplug it and plug it back it back in it is the same, only runs if I start it manually.
Does this mean that the fan motor is bad?
Update
Thank you again Old Turkey.
I changed the motor and it seems to be working fine now.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Rich Fahey, if by "start in manually with my finger it will run." that it will run when you start spinning it, then yes, your motor could be. It is possible that the start winding on your motor have failed (most likely), but this can also be caused by a bad start capacitor. Safest bet of course would be to replace the fan motor. The replacement part number for your fan is WR60X10185. Hope this helps, good luck.
WR60X10185 - GE Refrigerator Evaporator Fan Motor 이미지
상품
$97.99
GE Relay Start - WR07X10084 이미지
상품
$59.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you Old Turkey . . . I will try that first.
Rich F. you are welcome. Thank you for accepting my answer.
댓글 달기
귀하의 답변을 추가하세요
Rich F 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 10
전체 시간: 663
