주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Anyone has a solution to repair my USB, no MB replacement?
Hi,
I have a Macbook Pro, early 2011 "13.
One year ago, the USB port closest to me stopped working. It's strange because if I connect a device (like an external HD), the power lamp burns (without effectively powering), but it's impossible to connect.
I already tried several things, but so far, no solution.
Would a clean instal of OS X do something?
The MPB isn't in guarantee anymore and I'am afraid a repair would cost a lot of money.
Thanks for you help,
Thomas
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
It's possible you blew the fuse link on the USB ports power services. Try using a self powered device to see if that works.
You could also try running AHT to see if it sees a problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can try to reinstall OS X, but I don't think it'll solve the problem. It looks more like a Logic Board problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Thomas Kindermans 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 3
전체 시간: 191
