주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
How can I repair a keyboard?
Is there anything I can do to repair a keyboard,my logic board is fine after I've used it for months it even chimes after a restart,at the moment I use the on-screen keyboard and it doesn't start, I have to boot it from the back.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
That is a very expensive way to repair a keyboard on a MBP.
I would recommend following that guide but when you get to the point where all the components are removed (which are in the way of the keyboard) start carefully removing the backlight diffuser panel and the other plastic panels between the keyboard and backlight.
Next you have lot of screws to remove, takes about 15mins to remove them all. Once these are removed please don't forget about the power switch as that is attached to the keyboard. it is covered by a small metal plate held down by two screws, just remove them and you should be able to lift the power button out.
Thats it the keyboard is removed, these keyboards are readily available on eBay and do not cost much, much less than a whole top case anyway. Here is an example, UK eBay site http://www.ebay.co.uk/itm/Macbook-Pro-13...
If you need more help or a step by step please ask and I will be happy to help.
Cheers
Brendan Mills
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
That seems like a better idea. Based on the guide, I wasn't sure whether or not the keyboard could be removed.
Yeah it can be removed just takes a little time removing approx 60 screws, maybe I will do a guide soon.
댓글 달기
It looks as though the keyboard is attached to the upper case. You can use this guide to replace it. This is the part that you need.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Upper Case 이미지
상품
$49.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gregor Jordaan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 255
