주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
Can dual hard drive kit be used with a data doubler kit?
Trying to keep the original hdd drive in my mid 2011 imac, and maybe misunderstanding that I can add 2 ssd drives via cables and a data doubler!! Am I off base on this idea?? Through your ifixit company 1 ssd drive will go under the optical drive, but using a data doubler will use the optical drives existing space. Is this far fetched or this is correct?? Thanks for any help on this issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
You only have three SATA ports in your system (older models only have two). There is no way to split the SATA port (expanding beyond what you have).
Currently you have two in use (HD & Optical drive). Apple added a third port as people wanted to use a SSD for a boot drive (to speed up the boot up). Later on Apple introduced the Fusion Drive service to make managing the storage space easier as one unitized volume and allowing the OS to place the files on the best storage area.
If you want to hold on to your HD & Optical drive then you have the third port to connect your SSD to using the special Apple SSD bracket ($$) or just some double stick foam tape (the SSD is not very heavy). If you add in a second HD I do recommend the bracket as the heat dries out the tape.
If you want to add in a second SSD (or have an older iMac) then you can use the OWC (Data Doubler) or iFixIt Optical drive bay carrier replacing your optical drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It is correct but it's a lot of work. Getting and using one large external drive is much simpler.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Timothy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 835
