주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
No sound on both side when making a phone call!
I have bought a second hand iPhone 4S, everything is function except when making a phone call, we cannot hear each other side voice! Even I put on speaker phone mode! And the mic works when using recording apps. I have also updated the latest iOS 6.1.3
Which IC is control this function ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
there are two mics on the iphone... one located on the dock connector and one at the top under the motherboard... the mic under the motherboard is the mic used to intake sound while recording videos and sounds on apps while the mic on the dock connector is used to intake sound during calls... the mic on the dock connector needs to be replaced and luckily does not require total dismantle of the iphone... you need to buy the whole dock connector part which is extremely cheap...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for your suggestion, let me try it out, hope it will work.
댓글 달기
귀하의 답변을 추가하세요
Henry Tang 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 317
