주요 콘텐츠로 건너뛰기
eMac은 교육 시장용으로 설계된 올인원 G4-기반 Mac입니다. CRT 화면을 사용하는 마지막 Mac이었으며 학교 및 기타 기관에 저렴한 가격으로 판매되었습니다.
20 질문 전체 보기
Can I replace my CD/DVD drive?
My eMac has a broken CD/DVD drive so I am not able to upgrade my operating system, etc. Can I replace it with a new drive and then upgrade it to a current software version?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 6개
선택된 해법
Here is a link on doing just that. codyduncum is correct in checking what operating systems your eMac will run. No eMac will run Snow Leopard but the newer ones with enough ram will run Leopard. When you get to the site click on eMac disassembly. Ralph
http://www.wilko.com/
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Here is a link to the versions of OS 10 and their requirements so you can tell which OS your computer will run. Ralph
http://www.twistedmac.com/index.php?opti...
nice link ;-) +
I try to save good information. Note I modified the link to get it to work here. Ralph
댓글 달기
I had a similar problem with my internal CD/DVD drive. I haven't replaced it yet, but I purchased an external CD/DVD R/RW firewire drive for which I was able to boot the eMac. I solved a majority of my problems.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have serviced many of these models. The machine is not picky at all as to what you replace it with. Just use a qaulity drive so you wont have to replace it in the future. It take about a half hour or so.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
What is worth in 2012 to answer this question... :) I have just replaced the DVD drive in an eMac 1.25GHz.
It was not that difficult to be honest, but takes some time and effort, following carefully a Macworld 2005 article about this very topic.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Another optical drive is not all that would be necessary. Depending on what you are trying to upgrade to, depends on if you have the necessary requirements such as RAM, or processor speed or type. A new optical drive would work, but be careful knowing that might not be the only thing necessary to fix / update to install a new operating system.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Its1/21/18. I just took a hammer to mine. how can I fix it ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kirk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 5,807
