주요 콘텐츠로 건너뛰기
Logic board is out I guess?
My Grandfather bought this machine for my Mom means alot to her and need your help. My Mother took it to a repair place and they said the logic board was out how can I tell and can you get me the parts? If its not the logic board will you take the part back?
Thanks, Greg
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 9개
hi greg,
what problem does the iMac have ?
"logic board" can mean many things
Will not boot-up. The place she took it to said they tried a new power supply and still not booting up. There answer is to replace the power supply and logic board. The labor for this would be to much for her so I thought I would give it a try.
does the iMac react in any way whe you press the power button ??
No, but I can feel heat on back left of the machine. Could it be just some Capacitors?
it would be possible.
use the guides to open the iMac and look at the capacitors.
if they are bulging or having a brownish substanc on it, the are dead and have to be replaced
when you open the iMac and start it - you should be able to "feel" where the heat is coming from - but don't touch anything *bzzzzzz* ;-)
댓글 4개 더보기
댓글 달기
답변 1개
선택된 해법
You will have to remove the logicboard (quite easy on these machines) in order to get to the underside of it. Then you can check the capacitors with an ohmmeter. A good capacitor should have a steep rise in resistance when connected. Visual inspection is sometimes not good enough. The capacitors on these machines are prone to failure anyway and should be replaced with higher rated parts. No easy task.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
gregcorcoran 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 2,557
