주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
295 질문 전체 보기
질문 마감됨
Could I use tin foil to replace teeth on logic board?
I know its a ridiculous question but yea my iphone is missing a tooth from were you connect the dock cable and since aluminum conducts electricity what came up to mind is to apply a small amount of tinfoil in between the missing tooth to see if it would stop overheating sorry if a dumb question but i am desperate and dont have a soldering gun.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Post a couple of images of the connector etc. With your question. Here is a guide on how to add images. Adding images to an existing answer it will be easier if we can see what you see.
댓글 달기
답변 1개
Well the tin foil is a conductor but is not going to fix your problem.Also it's not safe to use tin foil. I would recomend you to order a spare part over the internet and change it. It's easier and safer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 205
